2 steps forward, 1 step back.
Engine now turns over, with key on I can hear the bladed clutch "click" when I move the switch to engage/disengage. Engine will not start.
Seat switch was also pulled out from it's connector but looks okay so I just plugged it back in. If this was damaged also would it still allow the engine to turn over and not start or as on some mowers I have had the engine shouldn't even turn over.
Should have asked this first, is there any way to bypass the relay?
