Dixie cut height
wjb
does any one know how to set the deck height the height number does not match the cut height 2013 classic with 29 hours
I had the same problem, I have a 2009-2760 Classic, what I did was cut 4 blocks of wood at the height that you most commonly cut (mine is 3.5 inches) raise the deck fully, place the blocks under the tips of the 2 most outside blades, place the stop pin at 3.5 inches and lower the deck into place, then use the deck lift points to adjust the deck up or down whichever you need to make the measurement. I've found this "trued" the deck height adjustment and now all my settings are accurate, (give or take a 1/4 inch). note: perform this on a level surface.
Hope this helps you out.
