Tcarp96 Forum Newbie Joined Mar 28, 2026 Messages 3 Jul 26, 2026 #1 Went to change the blades on an Old Zee 2 48” I inherited. Most of the blades out there are 16.5”. The blades I took off measure 16-15/16” in length. I found a set of 17” blades for a 50” Dixie. Do I need those rather than the 16.5s? Thanks!
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,588 Location Pluto Jul 27, 2026 #2 DC 300819, 301068 is a 17-1/4 x 2-1/2 x. 203, 1/2" Center Hole blade Hi Lift. Look it either it is either a DC or Oregon 92-141 blade. The Stens 310-030 is NLA as of 2024.
H hlw49 Lawn Addict Community Leader Joined Jul 11, 2021 Messages 2,134 Location Tennessee Jul 30, 2026 #4 You measure the blades from cutting tip to cutting tip not straight down the length of the blade.
