Dixie Chopper T box repair help
mikeeee372
2000 DC XW2500 tbox leaking oil. Can the seal be replaced? If so can it be done from under mower by removing just the pulley. Gears in box are good. Bearing seams to be good but I do not know if the seal is made into the bearing. Any help always appreciated. Thanks Mike
mikeeee372
So I was able to cut the pulley off and replace the oil seal from underneath the mower without having to remove the tbox
