Having a corner lot and being a good citizen that follows and obeys village ordinance, I'm obligated to maintain an easement that in my case consist of a ditch 750 feet long. Most of the ditch is narrow and shallow, no big deal for a 30" rider. Takes three passes to cut the easy part. But the first 200 feet is deep, about 3-4 feet deep to be exact. I cannot mow up and down (perpendicular to the ditch) because of a line of trees that run along my property. In fact, my little JD130 will tip over if I were to attempt to mow the deep part. I do not want to damage the engine for the luck of lubrication if I were to install wheel weights to keep center of gravity lower to the ground. I have used a trimmer in the past but it took me 2 hours, looked like crap and it was tiring! What are my options? Electric push? 2-cycle maybe?
