Dirt Tornado!
StretchXXL
I have a YTH24V54 equipped with a mulching "plug" and mulching hi lift blades, the end of mowing my yard I am covered with dust and mulched grass! Has anyone had this problem and is there a fix for it? Thanks, StretchXXL
Tiger Small Engine
Remove mulch plug and put an exit chute on, problem solved. Mulching doesn’t work well on a riding mower or zero turn anyway.
Mulching works fine if you have a deck designed for mulching, most are not, just say so. My 1996 Toro 16-38 has been mulching only since I purchased it and does a great job. To bad todays mowers are not built like this one.
