I put diesel in my gas Exmark mower. I drained the fuel out and it started back up. It will run like normal for a little bit the act like it's not getting any fuel. What else should I do?
Bearing in mind diesel is more of an oil than gas, I'd replace plugs which are probably fouled up and pull the carb for a thorough clean. Be glad it wasn't gas in a diesel...!
