Hi folks,
I have an older John Deere GT262 with the Kawasaki FC540V. The circuit board in the ignition switch went bad so I rewired the whole tractor using a generic keyed igniton switch from Autozone, and then bypassed all the safety switches as well as the PTO to work with generic toggle switches. The problem im having is that it will turn on and run great, but when i turn it off it blows the ignition coil and wont restart. I replaced the igntion coil and the same thing happened. I started it up and drove it around and then turned it off again and the ignition coil blew again. Was there some sort of resistor in the circuit board that I need to add to the ground wire that goes to the coil? Any other ideas? Thanks in advance....
