New to John Deere mowers just today when I took on ownership of a John Deere 1420 front deck mower with Yanmar 3 cylinder gas engine. 737 hours from new. Seems to be in real nice shape, definitely not abused in any way. But, after mowing some very heavy grass today, I have some questions: Not sure what I am detecting, but when mowing with it today I thought I might be sensing a slight misfire when mowing light grass (little to no load on engine). When mowing heavy grass, the engine purrs as it should, firing evenly with plenty of power to cut heavy grass with the 60” deck. Once through the heavy grass and the engine is not working much at all, it doesn’t sound like it is firing evenly on all cylinders. Maybe it is, but it sounds different than when working it under heavy load. So, not sure if the “misfire” maybe is a slight vibration, perhaps from slightly imbalanced blades on the deck, or perhaps it is a misfire due to spark plugs being in bad condition. Under no load, low idle sounds good. Not perfectly smooth, but quite good. At high idle, no load it runs perfectly.
So, tomorrow morning, the blades will be removed for sharpening and balancing. After that, will pull the plugs for inspection. Anyone here with experience running a Yanmar 3 cylinder gas have any thoughts as to what I may be detecting?
Vvm
Vvm
