Deck brake assembly spring
hollow1107
I have a 2001 huskee gt 46 inch deck
model 14AJ848H131
I was changing the blades belt it was getting dark and when i was removing the cover for the right pulley i seen a spring
I am not sure where this spring was attached. I do know it was attached to the last bolt i removed
gfp55
model 14AJ848H131
You may find what you are looking for at partstree.com just put your model number and all the info it asks for and you should find a parts diagram of your deck
