Damper Change
Zz101
I have a Gravely ZT HD 48" w/ Kawasaki 24.0 Machine 160 Hrs. I think added wear & tear is due to the hilly property. Left Steering Damper has failed. The Damper is located in the back and above the left-side trans. Acess area is tight. Do I need to drop the trans to change this Damper. Thanks in advance.
