D170 Wheel Shaft Question
Laabk2
It should be noted that once you buy John Deere, you are married to John Deere. Parts are expensive, and MOST are only available from JD. The same is true for their BIG farm machinery. Then when something unavailable from JD breaks, you're dead in the water. My brother in law needed a wiring harness for his tractor. It was made at a factory in Ukraine. Guess what. The factory no longer exists. The JD factory was out of the harness. The dealer finally found one in stock at another dealer out of state. FedEx had it here the next day. Several states, and even the federal.house, have attempted to pass RIGHT TO REPAIR bills. I don't know that any have passed and made a difference. Those laws would force manufacturers to allow access to parts and repair information, including John Deere.
The computer programs are available for the John Deere equipment at a cost but again you run into the issue that so many parts are "John Deere" exclusive. I have even encountered problems working on the small equipment like gators. Kawasaki makes the engines but the carbs are John Deere specific and only available from John Deere. It wouldn't be such a bother if the equipment worked better and had a longer life between repairs but that too has gone to the wayside.
Auto Doc's
Hello MG,
If it is over 8-10 years old (with many like JD it is seldom 5 years) manufacturers will no longer make the parts, and they are simply depleting old stock.
Companies no longer lease and maintain massive warehouses full of parts that just sit for years. Even when built new, they use a process called a "just in time supply" process to avoid overstock and clutter.
When it comes to rider equipment, there are more aftermarket sources for JD riders than for the farm tractors.
wolf865
Now for the rest of the story. And I'm kicking myself royally every time I think about this!
I was fixated on finding a wheel spindle that exactly matched the one that was on the D170. What set it apart from the ones that I was finding online was that it only had one upward tab on it, which is probably some sort of turn limiter? By this time I had ordered and returned two different sets of wheel spindles that were supposedly for the D-170 from AMZ. Unfortunately both had come in with the wrong (2 tab) spindle and didn't look like the single tab wheel spindle that their ad pictures had shown. Had contacted two different JD dealers by this time and explained exactly what I was looking for (single tab) and they said didn't have what I needed.
Wife nagging me about getting her mower fixed so I decided to just bite the bullet and pay whatever the part would cost me if I could find a dealer/seller that carried it. Since the first two dealers had previously said the didn't have what I needed I called a third. They asked me for the serial number which I provided them. Yes! We have the part you need for the JD based on that serial number! I'll be right down I replied so off I go. Got there and they bring out a wheel spindle that has two upward tabs. Not the one I'm after I explained. At which time I was informed that they no longer make the the single tab spindle. It was replaced with the two tab version! So WHY didn't the two other dealers say that to begin with??? So I had returned two sets of AMZ wheel spindles already that I actually could have been used and had the tractor running in days instead of weeks.
In a crunch so I pay the $40 something, run home and install it. Fortunately the two front wheels fit the axle perfectly (the AMZ wheels are another story in themselves). Finally, success and wife will be thrilled to know she's back in business. Got around to explaining the whole dealer situation with the spindles, the tabs, etc. with her and how I could have used one of the two sets we had returned! That's when she tells me she never got around to returning the second set! That's when I really start kicking myself! If only I had know an hour earlier! That AMZ set came with TWO wheel spindles, all the washers, retainer clips, and the vinyl axle covers! And it cost less than $40 tax included. Could have rebuild the whole front end steering assembly for less than what I paid for that one piece from the John Deere dealer. Anyway, that's my sad story. Lesson learned. Hope your repair jobs go smoother! Will definitely be asking more questions if another repair comes up.
Auto Doc's
That is one of the biggest challenges on this site. Having people provide the proper information.
Always have you PIN (machine label) information. If it is for engine parts, have that engine label information as well, or the stamped numbers on the valve cover if it is a Briggs and Stratton engine.
Those are the numbers are the first thing a good parts person (or people on this site) should ask you for.
The hood model "call out" labels and model stickers are not always correct.
When I was a JD service manager, I would screw with a new tech by simply swapping hoods. I would let the parts person know what was going on and they would send the tech back by telling them to look for the correct PIN number. Most of the "D" series riders had interchangeable hoods.
