D170 engine not start unless blades engaged--Help????
EQUISLUVR
  • / D170 engine not start unless blades engaged--Help????
Bought from individual yesterday and engine will not start unless the blades are engaged. Seems backwards and unsafe to me. Operator's manual section Testing Attachment Engagement Switch or Lever says if engine starts w/ blades engaged there is a problem with safety interlock circuit. Can anybody confirm? Info on process to correct ? Thanks
JD318420
Look the board over, any fuses or relays, check those. Look for damage burns, ruptured components. If there is damage then the board will have to be replaced. If a fuse then the short or reason for the fuse going will have to be checked.
EQUISLUVR
JD,thanks for info. Location of the board???
EQUISLUVR
Mechanic Mark,
Thanks for info. Yes MTD not my mower but I read the link in its entirety and makes sense. Will begin checking all tomorrow morning. Thanks again!
