Thanks! Your book has a section that explains how to de-carbon the exhaust. If I were you, I'd buy up all you could of the nos parts. Even if you don't need them, if you plan on tinkering with old Lawn Boys, you will at some point haha I have an old dealer near me that I have bought a ton of stuff from, and I've had good luck selling some things I didn't need on eBay. Thanks for keeping an eye out for the piston. I'm seriously thinking of rebuilding the one I got today instead. It seems to run fine, but I can hear the slack in the engine, and the compression is decent at best. The piston should be good enough to reuse. I learned that the bronze lower bushing has to be machined out to accept a F engine needle bearing as a replacement. This should make the engine a lot smoother.
