I picked up a JD LX255 at a great price but the guy was shady about what was wrong with it. I had to replace the head gasket and do a complete breakdown on the carb. At some point someone has tinkered with the linkages and it appeared that the carb had caught fire because the choke plate cap was melted and I had to put on a new choke kit.
I got it started and running, but it runs at dangerously high RPM. I have to move the throttle lever to the low throttle position to run it at the normal operating RPM. Moving the throttle lever up increases the RPM's significantly. I've also noticed a significant loss of engine power when the PTO is engaged.
The carb itself (Walbro) has two adjustment screws, a low idle on the top and a fuel mixture screw on the bottom right (in the picture). There are two adjustments on the linkage, what appears to be a low and high throttle limit. I've made minor adjustments to all of those adjustment screws just to see if anything changes and it did not.
Any suggestions would be appreciated.
There are two pictures of the linkage, one with the throttle in the high position and one in the low position.
