Cutter Deck
colts82
We recently purchased a SCAG Tiger Cat which I love, my problem is I have grass coming out from everywhere under the deck. By the time I'm done mowing I'm covered with clippings/dirt etc... Why are the clippings coming out from the front of my deck? I have the cutting deck set at just under 4"
mechanic mark
Request Rejected locate your serial number then operator manual & see troubleshooting section, also check air pressure in all tires per manual, check blades for replacement or dressing up with file & balancing, & deck for being level per manual.
