I understand commercial mowers/decks are designed to cut nicely, even when grass is wet or overgrown, but is there a difference for a homeowner who cuts weekly and only when the grass is dry? I typically cut 4-5" growth down to 3". I'm trying to decide between the Hustler Raptor SD 54" ($4000) and the Ferris IS600Z with the 48" iCD deck ($5500).
My property is almost an acre, and using the cool Google Earth area measurement tool at daftlogic.com, it looks like about .55 acre of it is actual grass. So I figure 25 hours a year usage max. Based on that, and my yard being flat, most of the advantages of the Ferris over the Hustler (ZT-3400 hydros vs 2800's, Kawi FS engine vs FR, 10mph vs 7.5mph, ROPS, 4 year warranty vs 3 year) don't seem worth the extra money for my situation.
No real differences in the dealers, either. Both well-established businesses, nice folks, and both are 3 miles from me, practically across the street from each other.
So for me it just comes down to the quality of the cutting, mulching and striping. I plan to get the mulch kit for whichever I buy, and use it always (I always mulch now with my push mower). I also plan to get the Hustler striping kit (the Ferris comes with one). I'd like to save the $1500 difference, but if I end up with stragglers and clumping and such, I'd rather have spent the extra IF it would've gotten me better results.
What's your opinion?
P.S. Borrowing a demo unit would be be ideal, but I don't have a trailer, and would also worry I might damage their mower since I'm new to ZTR.
P.P.S. the Hustler is 650 lbs., while the Ferris is 954 lbs and has narrower tires, front and rear. Should I be worried about ruts?
Both have a high bts, so either should leave a nice cut.
there are No guarantees of a better result or that you wont end up with the same results from the more expensive mower.
Personally I'd go with the Hustler because it's all the machine you'll probably ever need for the job your doing so why spend the extra money. You say you don't want to deal with the possibility of stragglers and clumping and such and I'd rather have spent the extra IF it would've gotten me better results but the fact remains that even spending the extra money there are No guarantees of a better result or that you wont end up with the same results from the more expensive mower. The only thing that you can guarantee is with the added weight of the Ferris is leaving ruts in your lawn faster especially if it has narrower tires, front and rear.
I alternate paths each time I mow and I don't have a problem with soil compaction.
Hmm...do you mean you shift over half a mower's width from where you cut last time but go the same direction, or cut at a 90 degree angle to how you cut last time? Here is my yard: On either side of the house, going left to right instead of up and down would be...well, not impossible, but kind of tedious, particularly on the left side. The strip by the driveway is only about 160" wide and these mowers are 73" - 80" long :smile:
Bought my Toro Timecutter 8/20/14, & no regrets, it cuts beautifully.
I don't know about about the mulching, since I never do it. But it is a Kit, that has baffles & etc.
Great, thanks, it is always nice to hear first-hand experience. What sort of grass are you cutting? With normal weekly cutting do you ever find yourself having to slow your speed to maintain cut quality? Do you use the wash-out ports, and if so, do you find them effective?
I considered the Timesaver but then went more commercial. I have found with the higher blade speed and weekly mowings that the trimmings are much smaller than with my old Craftsman Tractor. It leaves no stragglers or windrows. I would try it without your mulch kit first and without touching the deck pitch. They set these things from the factory and maybe they got it right. I know they did on my Fastrak SD. Striped nice right out of the box.
Enjoy it and happy mowing.
Hope you got the Toro End of Year Sale Price. I saved well over $400. last year when I got mine.
FYI: To tell the year, behind the seat, look down & there is a cross bar that has the build date on it.
You may wanna inquire about warranty on spindles.
Anyhow, let us know how ya like it. & Enjoy.
Hmmm...no, I didn't. But the MSRP is $3200 and the dealer is charging just $3000. But that's the same price as Home Depot so I don't know if that's a sale or not. I don't see any mention on Toro's site about a end of year sale. How did you know there was one going on when you bought yours?
According to my Toro Dealer, Home Depot can't sell under a Toro Dealers price. If you see that & tell your Dealer, they will put a stop to it, & appreciate your input.
Nope, that was NOT the sale price. Talk to your Dealer, Toro Dealers have a year end sale every year in August for 1 week, that's when I buy my big ticket items. Not sure your Dealer works this way or not ? But they are supposed to.
Oh, cool, I will check for that. I'm pretty sure that the 2014 and below only had a two-position "Smart Speed" selector, while the 2015 has three, so I am going to check for that too. Definitely want to make sure they're not selling me a unit that's been sitting idle for a year.
Yep 2015 has 3 speeds. my 2014 only has 2.
I read through the warranty terms in the online manual and it's not listed as one of the non-covered wear items like belts or blades. They do say that any component failing due to normal wear is also not covered, so I guess it would depend on whether they'd consider water-damaged spindles to be "normal wear" or not. But if so, new spindles are only about $35.
Really ? $ 35. ?
Thanks, I will!
