Custom grater blade?
If I get a cub cadet wideframe, I want to build a belly blade out of a retrofitted mule drive. Can anyone show a mule drive lifted and lowered? And how do they mount? Thanks.
Darryl G
Belly grader is going to be of limited use if you're talking about mounting it under a garden tractor. Just not much clearance to work with.
I thought of that. It would probably attach the blade and mule drive straight to the lift arms, so when the blade lifts, it gets pulled forward and tilts.
Here's the design I came up with. Think it would work? Does anyone sell the quick attach pieces of the deck (the parts with springs which attach to the back of the mule drive)?
Cub cadet Grater blade V2 G.C..jpgCub cadet Grater blade V2 (3).jpgCub cadet Grater blade V2 (2).jpg
Darryl G
Cool. I see you upgraded to a levitation seat. :biggrin:
Yeah, state of the art, the most comfortable ride, not even being attached to the tractor.
