CubCadet AGS 2130 series 2000
yzinger
94 model, started every time till now, Battery good fuses good tried jumping from positive term to starter and nothing turn key and nothing i do hear a wimp click when turnning key so i think safety switch is working can anyone help please.
SonOfLiberty
Jumping from the positive terminal of the battery to the hot side of the starter may not be enough. Tyr jumping the ground side to the engine block at the same time. You may have a bad ground connection.
