Cub Cadet ZT50 (2006) PTO
UlsterMowing
Hey there, just bought a used zero turn. It starts up, moves just fine, no error lights. New clutch, new pto switch. I tested both they both work. Did a bunch of continuity tests on the wire harness. Someone removed the spring on the seat safety switch to bypass it when they get off. Any help/ideas would be very much appreciated
Auto Doc's
The actual sticker model number and the engine make would help us help you.
The seat switch spring missing may be the issue. Some of these mowers would let the engine still run when bypassed, but not the PTO clutch.
Chickanic on You Tube has a pretty good video about testing safety switches that you might want to check out.
