I'm having a problem with my Cub Cadet. The blades only seem to engage when the lap bars are in neutral. When I pull them up and try to go forward the mower will go, but the blades stop. Also the mower has a noticable shake only when blades are engaged.
I replaced the PTO clutch last year and it worked fine until one day it just stopped in mid-mow.
I have tested the clutch, and it is at 3.4 ohms.
Any help and suggestions are much appreciated!
