Cub cadet zero turn not turning over
Alexwat
My grandpa put diesel in our zero turn lawnmower we replaced the fuel filter the fuel pump and cleaned the carburetor and checked the hoses but it still won’t start it only cranks any suggestions?
rainasdad
did you change out the spark plug?
Theyre cheap might be worth trying
Alexwat
I have replaced both of them it sounded a lot better but still wouldn’t turn over
hlw49
Try spraying carb cleaner in the carb intake.
Sure hope you cleaned out the fuel tank too.
I had a customer last to put 5 gallons of diesel in his Hustler mower. I had to clean the entire fuel system.
Alexwat
I took the hoses off and ran fuel through it I wasn’t sure if that’s the proper way to clean it
