Cub Cadet Z Force S 48 Brake Lever Extension Spring Replacement
SMusgr0ve11
  • / Cub Cadet Z Force S 48 Brake Lever Extension Spring Replacement
Hello,
I have a Cub Cadet Z Force 48 lawn tractor and I recently found a spring that apparently fell off of it while I was mowing. I believe it is the extension spring that attaches to the brake lever, but I am unable to figure out how it should be attached to the tractor. The part number is 732-0963. I'm really not sure exactly where either end should be attached. I've searched extensively online, but haven't had any luck. Any help would be appreciated.
Thanks,
Steve.
mechanic mark
Look through your service manual Z Force.
SMusgr0ve11
I don't have a service manual for it. Is that available online?
SMusgr0ve11
That's great. Thank you very much.
gerolymatos
Click on Cub Cadet Service Manuals in my first post & locate your model & click.
Where can I find a sevice manual for a Cub Cadet Z Force SX48? Please help.
