Cub Cadet XT1 - Slipped Drive Belt? Not going Forward or Backward - appears to be a Drive Belt problem (slipped off of the idler pulley(s) ?)
JoeFromRomeo
  • / Cub Cadet XT1 - Slipped Drive Belt? Not going Forward or Backward - appears to be a Drive Belt problem (slipped off of the idler pulley(s) ?)
Cub Cadet XT1 - LT1 42"
Model #: 13AOA1CS056
Serial #: 18108H40302
Engine:
Kohler 5400 Series
18 HP /541 cc
KS540
SPEC PS-KS540-3011
Model KS540-3011
OK, so now that I've found out what was causing the 20 Amp fuse to pop - Thh Unit won't go into forward and reverse.
- The drive belt is engaged properly into the pulley on the rear transmission.
- The drive belt is also engaged properly into the pulley on the engine.
- You can pull on the belt, and it is not cut in two or anything.
- Apparently it has popped off of the idler pulleys in the center of the mower?
- Does anyone seen this happen before?
- Any words of wisdom in how not to have to drop the deck and get the belt back onto the idler pulley's?
Thanks for any help.
mechanic mark
Always use Cub Cadet OEM Parts & always remove & inspect Idlers for wear by hand when replacing Drive Belt or Servicing.
