Cub Cadet XT1 Enduro - ignition module
RubyMtLawns
My Cub Cadet XT1 Enduro - the ignition module is bad. The slot where the key goes into seems to be stripped or worn. Being that this seems to be made from plastic, the key doesn't work when all the way in the slot anymore. You have to pull the key slightly out and then turn it. I'm afraid it isn't going to last much longer. Has anyone had to replace this module? And is there an aftermarket one I could use that isn't going to do the same thing as this original unit has done?
As always what is the model number from the serial number tag?
