Engine Cub Cadet wont fire
MartinD
Trying to fix a 48" cut cub cadet. It has the CH18S-92509 Engine. I tried disconnecting the white wire going to the engine from the double yellow wires going to the harness and still no fire. Im told there are two coils on this. Im not a lawnmower guy. Any ideas?
Deerlane
The white wire is the tractors ground kill wire, so you isolated the engine from the tractor, Good. Make sure it's only the white wire!
Is engine is cranking? Do you have spark at plugs?
