Cub Cadet transmission oil change
Scrubcadet10
Moderator
Staff member
2010 Cub is getting at 200hours now. When (and how) should I Change the heat oil? Thanks.
Scrubcadet10
Moderator
Staff member
Idiot me. Just realized that said heat oil. wrote it with my tablet (always blame auto correct) When should i change the transmission oil. and how
BlazNT
That all depends on what Cub you have.
Scrubcadet10
Moderator
Staff member
it's the one that cuts grass with blades.:wink:
2010 Ltx 1040,
BlazNT
I downloaded and read your manual. This is what it says about your tranny.
"Transmission
The transmission is sealed at the factory and is maintenance-
free. The fluid level cannot be checked and the fluid cannot be
changed."
Where did you get that it need to be changed? Not that it can not be changed but Cub is calling it sealed.
Scrubcadet10
Moderator
Staff member
Thanks for the info. :thumbsup:
I figured the oil in it would have be changed eventually. Just wondering how.
Thanks again.
BlazNT
I guess I should have put this in the last one what is your tranny and I can look it up on their website as to what they want you to have.
