Hi,
I own a 15 year old Cub Cadet Tank, 19HP, that is not steering properly and has lost its' old top speed. With the right lap bar pushed full forward travel the left bar has to be held behind the right bar by about 2" in order for the machine to track straight. Higher speeds can be obtained by pushing the left bar full forward - if I want to go in big circles.
This mower used to fly with both lap bars pushed forward equally against the stop bolts. I'm hoping there is simply a small hydraulic filter on the right hyd. motor.
Any advice will be appreciated.
Thank you,
Shay
Thank you,
Shay
