cub cadet steering issues
dkempp
Hi
I have a cub cadet rtz50 zero turn. I need to adjust the speed of either the right or the left so the machine tracks properly. also there must be a switch that turns the mower deck off and on when in reverse, this switch is out of adjustment and turns the deck off when still in forward or close to neutral making it impossible to cut around objects. Any advice would help.
Thanks
Derrick
npikecatcher
the switch is directly under the reverse pedal. it cuts the blade off when pedal depressed and can be disabled by removing one bolt and lowering it down so pedal doesn't make contact.
