Burkhart Bowfishing
- Jun 2, 2018
- 1
- 1
I've got a Cub cadet RZT 50 zero turn I picked up not running Model # 17BA5A7P709
When i bought the mower the wiring harness was completely melted, pto switch burnt up, pto clutch was fried. I replaced the wirning harness, the PTO switch & clutch (OX Clutch), installed new battery. Got the mower running and drivable, but when i went to do the clutch break in it did not engage at all, I checked voltage to the switch but dont have voltage going to it, I did notice when i installed the wiring harness i have an extra plug on each side under the console from the harness that have no place to plug in, I figured they were for a different option for another model, only thing I havent replaced is the silonoid & the ignition switch, can anyone help me out.
