Cub Cadet RZT50 Deck Leveling Question
JonnyBlaze
2011 RZT 50. Is the right side (when sitting on it) supposed to go up and down the same height as the left? I replaced a broken deck lift cable with the NPW deck lift bracket upgrades today. The only adjustment is on the left side and on the front. The one on the left just raises and lowers the left side.
When I moved the lever up and down, I dont really notice any up and down movement on the right. I see the internal lift arm moving up and down. On the left side the deck moves up and down a lot. Not sure if that's how it's supposed to be or what ...
BlazNT
Yes, when you raise and lower the deck everything goes up or down. If not one of the connections is not connected. Look around under the mower. You will find it.
