Cub Cadet RZT 22
Arauthator
So the PTO just stopped working while in the middle of mowing today. Not a belt issue. I don't have my multimeter with me today, but I was thinking the PTO relay may have gone bad. However, if you turn the PTO clutch by hand while the mower is off of course, it turns quite easy. Is that normal from a PTO clutch? Checked reverse switches, they seem fine. No fuses blown and have the correct ones. Nothing goofy has ever been done to the mower, its all original from the factory and never been worked on apart from replacing blades and wheel assemblies or a battery here and there.
Also, what ohms should the reverse relays, the clutch wire connection down by the PTO Clutch, and PTO Relay read on an ohm meter?
Thanks in advance.
Arauthator
Thanks man. I'll troubleshoot this issue tomorrow. Good links by the way.
