I have a Cub Cadet pushmower, Model 94M with Engine Model - 1P70MO.
Trying to address a surging issue - seems to surge when hot but not constantly. Periodically will almost stall and when surging doesn't burn clean. Can make it better with partial choke.
What I've done:
Re-cleaned carburetor
Verified spark plug @ .030
Plug/oil/air filter/fuel filter new late last year. Fuel is fresh from a month ago, started after purchasing this fuel but I had also removed and cleaned carb at same time.
What I'm planning on:
Using fluid (carb cleaner? Fuel injection cleaner?) where carb meets block to rule out air leak - based on issue when hot and partial resolution with choke.
Should I re-examine the carburetor? Initially I thought this happened when hitting bumps and was leaning towards week spring on float and was thinking about rebuild. Any way to test the governor?
Thanks in advance!
-Eric
Videos of son mowing neighbor's yard - you can hear surging:
https://youtu.be/CJSRtrVsX0o
https://youtu.be/QcxtFUXv53M
What I've done:
Thanks in advance!
-Eric
