Cub Cadet over reving
wmg2
My neighbor, that I am helping with, has a Cub Cadet series 1000, OHV twin that runs wide open when started. All the linkage and springs seem to be in place. When the throttle is held closed on starting it will idle, but as the throttle shaft is moved it will go to all the way wide open with not end to the top speed. There seems to be no governor action at all on the shaft from the governor. Is this where the problem is?
impalass
Could be sticking.
Fish
Could you give us the brand and model numbers off of the engine?
briggs
Check to see if the shaft has play in the carb housing the carb my be worn out have seen this happen it causes the carb to suck air and rev
wmg2
Thanks. Will check this when I get home this weekend
wmg2
Will get this info when I get home this weekend
The engine is a Briggs
Model 407777
Type 0128E1
Code 000118YM (possibly an H as the last letter)
