Cub Cadet LTX1050VT not charging
mjw357
Wife went to start tractor this afternoon, no go. Checked battery, 11.8v or something. Jumped it to start, 10.something across terminals. So the ignition/headlights are pulling it even lower while running, obviously not getting anything from the charging circuit. New battery as of last September.
Have battery on charger as I type this. Engine is B&S 24HP twin. Single black wire running up under flywheel area. Green connector to yellow wire to regulator/diode. Red wire running from regulator/diode out to tractor. Reg/diode is about 2" square by 1", bolts to engine shroud.
What voltages am I looking for? Easy way to test alternator/stator?
mechanic mark
mjw357
Thanks for the reply.
This manual references two white wires coming from stator, and shows a 3-wire type regulator.
I will try starting the engine and testing for AC voltage from the stator, then checking the output of the regulator. From What I have read and tested so far, I am leaning towards a bad regulator.
EDIT: Started mower, black wire just above idle about 30vac, at full throttle 42vac. Connected regulator, at full throttle, only getting about half a volt DC.
So, bad regulator I suppose?
Make sure you are getting 12 v from the battery at the wire that connects to the voltage regulator.
mjw357
Post all numbers from engine data plate, model xxxxxx, type xxxx, trim xx, code xxxxxxx.
B&S model 44M777
type 0720 B1
code 081219YG
There is 12.8v at red wire.
Ordered replacement for part # 491546.
