If the solenoid is stuck and you start the engine with carb cleaner, etc., something has to dislodge the stuck solenoid or the engine would die shortly if it doesn't get unstuck.
But, engines vibrate and maybe this vibration is what unsticks the solenoid?
You can test this by turning the ignition key to 'on,' then lightly tapping the solenoid prior to cranking the engine. If it starts, you've found the problem.
I have checked that the Fuel Pump is functioning properly for supplying fuel.
The fuel Solenoid (on bottom of Carburetor) evidently is the reason for lack of fuel supply to the Carburetor.
It does not activate to open the gas entry to the carburetor -- when turning on Key.
I removed the Solenoid to test-- and when applying 12 volts through the contact wire (with proper ground contact for the unit) does NOT activate/energize the Solenoid to pull the "plunger" down to open the fuel port.
The "plunger" was stuck and rather difficult to move in and out but finally loosened up but continued to not function properly.
As a test, I pushed the "plunger" all the way down (OPEN) and re-installed the Solenoid. The engine started normally. In fact, I mulched leaves for an hour, turned the engine off, let set for 20 minutes; and then re-started with no issues. So obviously, the opening for gas entry to the carburetor was not stopped by the Solenoid during this test
I don't plan to purchase a new OEM Solenoid due to the excessive cost but it seems the "After Market" units are more affordable. However, each parts diagram I have found only shows the Solenoid as a part of a Carburetor unit and NOT as a separate unit. Therefore, using Google; I have not found a "definite" part number for the Solenoid on my Cub Cadet with 20 HP Kohler Engine.
Of course, I found many MANY different Solenoids but have not been able to distinguish the proper unit for this Engine. Perhaps someone on this Forum may have experience (and resources) to identify the correct part number using the information from this engine which is listed below.
Cub Cadet LT1045 20HP Engine Numbers:
Note: I could not distinguish the proper character (even using a magnifying glass) so I used an * where the character appeared.
Family: 7KHXS - 5972G8
Type: e11*97/68SA * 2002/88*0285*01
Disp (CC): 597
Model: SV600
Spec: SV600-0009
Serial: 3715012943
Build Date: 05-30-2007
Lawn Mower Identifications:
Cub Cadet LT1045 Lawn Mower (1 Cylinder 20 HP)
Model: 13RX11CH756
??? : 621-879
Serial #: 1F137H10222
DOM: June 2007
