I have a cub cadet. LT 1045. Its about 5 years old. A couple weeks ago, I was cutting the grass and it just turned off and wouldn't start again. I checked the battery and it was good.
Today I replaced the fuse. It started up immediately. The lights came on but nothing on the displays were showing. I started cutting grass and it was going fine, but I noticed that although the battery quality light was working it was not showing hours run. Also I could not turn on the reverse option that keeps the blade turning if you back up and the light would not come on for that either. In the middle of cutting grass it turned off again. No lights. No power. Nothing.
I replaced the fuse cause it was burned out again. It still would not start. A red light flashes for a millisecond then goes out immediately. Nothing works. I have replaced the fuse 5 times and it does the same thing.
Any ideas on what may be causing this? Any help would be appreciated. Thank you.
