Cub Cadet LT 2042 Rear Hub Assy Replacement
denniso
Needing to replace right hub assy need to know if I need any special tools or any helpful hints on doing the replacement... Thanks
denniso
Just take the center bolt out and the hub should slide right off.
Thanks, that was what I was hoping, just wanted to make sure I didn’t need to have it pressed on or needed any special details...
