- May 6, 2010
- 51
- 11,303
I normally jack up the rear wheels and put blocks under them to hold the mower up to give clearance without the jack being in the way. The pto clutch will have to come off which may some special methods to keep the engine from turning while removing the clutch bolt from the crankshaft or the use of an impact gun.Thanks. That parts diagram isn't going to be much help is it ??? I've replaced the deck belt before............and also at a later date, the spindles. I'm 80 years old and getting to where getting down on the ground like I'll need to do is difficult. But so is coming up with the funds to pay someone to do it for me.I've watched a few videos on YouTube University and they didn't pull the wheels. Why are you suggesting that ???
How do I check the functioning of the fans ?
Fan function would be to make sure the blades are not broken off or badly worn.
