cub cadet i1050
cave-man
Engine shuts off,will only start and run with choke on, replaced filters and removed filler cap,no luck
SONOFADOCKER
Carb needs to be cleaned or rebuilt . Great how to do videos on you tube .
Assuming you are using fresh gas....I would say clean the carb or adjust the mixture screw.
cave-man
forgot to mention, if it sets a little while ,will start and run fine for another thirty to forty five min.
Lawnranger
Next time this problem happens, check for spark. The coil could be intermittently going open when hot and causing a no spark condition. Typical symptom is when the engine gets hot is dies and after it cools down it will restart and run fine until it gets hot again.
Don't buy a coil until you verify it is defective. When you do find the problem, please come back to this thread and tell us what ultimately fixed your problem.
cave-man
Cleaned valve in bottom of carb, and started useing prem. fuel. Not sure which one fixed problem
