Cub Cadet GT3200 PTO belts keep coming off
vjs
Hello Everyone,
I was reading some posts on the Cub Cadet GT3200 and hope you may have an answer to this problem. I keep having trouble with the PTO belts coming of the lower pulley. I have replaced the belts several times. I was wondering if the pulleys are out of alignment or there is an issues with the PTO engage part.
vjs
Click on above website until you come to manuals then parts. Front PTO v-belt part #754-3084, pulley, PTO drive #756-3092, pulley, flat idler # 756-3094.
Always use Cub Cadet OEM parts. Idler pulleys & bearings inside do fail over time & can tear a belt up in a hurry. The best way to check & inspect idlers is to remove them & inspect visually & by hand both bearing & pulley groove. Hold bearing & spin pulley, does it drag, have sloppy play, can you hear noise from bearings while spinning, etc.
