cub cadet cc4025 trimmer
syrusdeadwater
unit works fine but off button won't shut off. how can i fix?
timtractor
Check to see if the wire connected to it has vibrated off and disconnect.
Clean all wire connections and then see if the problem is still there.
If it is the switch needs to be replaced.
