Jwilson22071
- Feb 24, 2021
- 6
- 24
Gas trimmer will not run once you take off choke. Changed the fuel lines, fuel filter , carburetor, gaskets, plug and checked the exhaust. Fires up 1st pull on full choke, as soon as I move to the mid choke position it dies. Starting at wot like the manual says but even at full choke it only runs at just above idle. Valves at set at spec. Coil works fine. Will run all day at full choke as long as I hold the throttle open. Compression is at 115. Any ideas?
