has anyone had trouble with the blades engaging & disengaging while in use?
L Lewis1947 Forum Newbie Joined Aug 24, 2014 Threads 1 Messages 1 Aug 24, 2014 / Cub Cadet 50 inch cut #1 has anyone had trouble with the blades engaging & disengaging while in use?
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 175 Messages 7,482 Aug 25, 2014 / Cub Cadet 50 inch cut #2 Cub Cadet Professional Shop Manuals https://www.youtube.com/watch?v=aN2Q9G3Wq-M Check pto clutch clutch connection making sure it's tight & secure. Fixing Electric Clutches I would check air gap at pto clutch per your manual from above.
