Cub Cadet 364 Deck Needed (or something similar)
BrewCrew
I've got a Cub Cadet 364 with @ 250 hours that needs a new deck. The mower has been left outside for much of it's life and rust has finally caused one of the deck pulleys to collapse....big reason not to get a stamped deck. The dealer says they do not make/offer this deck anymore. Also, if I could find a similar deck (current is 44"), I could have the attachment points removed from the old and welded on to the new deck. The only mandatory factor is it must be driven by a center pulley belt which runs to the clutch under the engine. Any thoughts?
