:confused2: Problems with lawn tractor fuel bowl acutator. Believed to be an electrical problem. For some time know I have had a off and on problem with the fuel bowl not filling with gas. Sometimes I could wiggle the red wire going to the bowl acutator to solve the problem. This must be a short in the wiring somewhere. I have un-taped the wiring back to the main harness and not found a short. I did note two red wires, with what appeared to be in-line fuse links, going into one red wire terminating at the acutator. I added a jumper wire before the two red wires ending just before the wire going into the acutator. Seems like the engine still wants to stall but a little choke resolves the issue. Could my "jumper wire" cause any problem and does anyone else have a better suggestion for a better fix?
Thanks gspald (new forum member) ****PLEASE HELP**** :confused2:
