Cub cadet 2130 john Deere 110
wwake0789
Hello I have a cub cadet 2130 and it starts fine and cuts good. Only problem is it will slow down to a crawl (if I'm lucky) when going up a slight hill. Any advice on why this is and how to fix it?
Also I have a john Deere 110 hydraulic lift which seems to have the same problem... that and when I run it I am covered in oil from the exhaust.
Advice on eithermower would be appreciated
wwake0789
Model # 618-3122
I can't find the access panel for shimming the clutch
wwake0789
I have all the covers off
