bryantsplace1
- Jul 4, 2015
- 7
- 15
Cub Cadet 1862 appears to have no spark. Ran great about 2 months ago. Have not been able to check safety switches because of rain.
Thanks Mechanic Mark. I will do all the things you suggest and give it another try. I am also going to check all the safety switches just to make sure they are not the issue.Is tractor kept in shed out of weather?Cub Cadet Service Manuals
Manuals and Diagrams for Cub Cadet Mowers and Tractors. Factory Direct from Cub Cadet. Buy Parts for Less.www.ccpartsnmore.com
Rain=moisture / Check oil level on dipstick, smell gas in oil, see moisture on dipstick? Remove sparkplugs clean them up, inspect for wear & replacement. Remove air filter, inspect carburetor & filter housing for moisture, clean-up as necessary. Check choke operation. give linkages a shot of lubricating oil. Inspect spark boots & plug connections. Pick up a tube of Dielectric Grease & use on all electrical connections, especially battery, spark plug connections inside boot, ignition switch plug, pto switch plug, etc. Drain gas tank & fill with fresh gas. One more thing, pick up a can of CRC Electrical Cleaner at Walmart or Auto Parts Store & spray a shot on electrical connections before using a Q-Tip to apply Dielectric Grease, give her a try, thanks Mark
Mechanic Mark, When outside today to do a little cleaning up and started getting things in order for colder weather. Tried to start the 1862 and it fired right up. Mystery solved itself. Thinking it may have been a safety switch issue.Thanks Mechanic Mark. I will do all the things you suggest and give it another try. I am also going to check all the safety switches just to make sure they are not the issue.
