Hi. Hoping someone might be able to help me out. My Cub Cadet 1720 no longer goes in reverse. I recognize it can't cut in reverse, which is fine. But, it no longer drives in reverse. It can only drive forward.
I'm not strong with this stuff, so forgive the ignorance. Attached is a pic of what appears to be a reservoir that sits on top of the transmission. Should the fluid be all the way to the top? If so, should I just purchase some hyrdo fluid / universal and fill it up?
I checked underneath the tractor and had someone move the gear lever / the arm seems in tact at the connection point under the tranny.
Any thoughts would be appreciated.
Thank you.
Thank you.
