Cub Cadet 1525 engage problem
john510
I have a cub cadet 1525 with about 270 hours on it with a Kawasaki motor, I noticed the electric knob to engage the blades sometimes cuts off at slower speeds and if I set the deck down to level 2, Whats going bad? is there a way to engage it with a straight switch or is it something else
john510
all these days and no response?
packardv8
There are so many wires going into the PTO switch and throughout the machine, they are a constant source of problems. Yes, if you're handy and can read a wiring diagram, you can change the switch, wire the PTO ON/OFF and solve a bunch of problems.
jack vines
